Old 10-22-2008, 06:22 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Terry,
You'd have to make a 3 sided box or a "U" welded onto the frame then two bolts through the plate (welded to the down tube) through the "U" bracket. Sounds good to me! Better than the original set up indeed. OR exactly like the top that mounts to the frame rail only this time your welded on upside down "U" would be a seat for the down tube and bolt in from the bottom up into the tube. Good idea!
DV
