Old 10-23-2008, 07:19 AM
petercory petercory is offline
Default Hood Scoop
Due to the crown of the hood, the Flange/Lip around the sides (not the back)of the original Contemporary fiberglass scoop was angled down slightly to ease the installation process. If yours is a hand laid scoop, there should be enough give in it to pop-rivet it in place without damaging it. To make the process easier, you may want to put the scoop under a heat lamp for a few minutes (it will make the glass a little more flexible) before installing it.
