Old 10-23-2008, 10:07 PM
cobras cobras is offline
thanks got the bug, been a long time waiting to get one of these cars.
im sure that if i lossen off the motor mounts and the tranny,side pipe mounts i should be able to shift over the motor, it would straighten out the clearance issues with the pipes. but then again who really knows untill i do it, i dont think it would throw out anything in the drive line, the drive shaft should compensate for it. even when the hood is closed and you look in at the air cleaner its not centerd with the hood scoop, its pushed over to the drivers side that quarter of an inch. weird as hell but that has to be the issue.
how about the clutch? is yours the same way, kind of slow to come back up when you let go of it? mind you its not bad but not as fast as i would like it to be,
and the gas pedal... seems a long way down to press before it activates the carb.
none the less i love the car still havent driven it beside getting it off the trailer and into the garage,,, no insuance as of yet till appraisal is done.
so i hope to be cruising the streets come monday or tuesday
oh and as for the tranny still no idea what it is will look at the plate when i got it up on the jack stands when im shifting over the motor....
