Old 10-24-2008, 03:04 AM
hogster hogster is offline
Cobra Make, Engine: King Cobra, QLD - 347 windsor
Default Relays - how many??
Well, I am up to my elbows in wiring, just routing loom segments and fitting out a dummy dash.............
What circuits should I run relays for.
I have a combination of two harnesses. One specifically for the Massflo-efi and an EZ2wire 20 circuit. I have stripped out the double ups from the 20 circuit but I need to plan which to run relays for.
I figured ....but I really am not sure
Lights - should I run 1 for high and 1 for low
Fuel Pump
Horn/Flasher is built into harness (the only relay)
Fan - controlled by EFI
Start circuit
Wipers
Stereo Amp
Demister fans
Does anyone know of a good reference for info on how to do these type of things, I just don't have $4K for a sparky.
Thanks again
Hogster
