Old 10-24-2008, 07:09 AM
McDoo McDoo is offline
Cobra Make, Engine: Former owner of Sp931
Originally Posted by madmaxx View Post
As far as pipe close to the body and causing blistering, I had a BDR where one pipe was 3/16" from the body and zero, nada, none paint or body damage. But again the closer to center you can get it the better. .
The exhaust temperatures at the point of exit from the body can easily get into the 800- 900 degrees F range with a stroked SB motor such as a 392.402 408 etc. If the timing is retarded just a little bit the exhaust temps rise under hard excelleration and will go way above those temps and these are all temps that can and will cause blistering so you need as much free space as you can get.
Check your timing often and replace that aluminum distributor hold down plate with a more reliable steel one so the timing stays true.
McDoo The real one
