  #31 (permalink)
Old 10-24-2008, 02:37 PM
davids2toys's Avatar
davids2toys davids2toys is offline
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Originally Posted by petercory View Post
The Problem is the Turkey Pan, with it on, the scoop cant flow enough air for a 500CFM much less a 750 or 780CFM Carb! Do a full bore accceleration run and shut the key off at about 6000RPM and take a plug reading - They'll be black with the pan on. Take the Turkey pan off and do the run again - if the carb is jetted properly, the plugs will read perfectly! We proved this out while tuning for a Run & Gun many years ago.
Also, if the filter element can only flow 470 cfm(mine)
