Old 10-25-2008, 07:07 PM
patrickt patrickt is offline
Default Two Ways
If it's the type that spins around without catching when the key is not in it you can spritz it with water then dump a little liquid freon on it to freeze it up. It will then twist off as if the key was in place. If it's not the "free spinning" type of lock then you can generally ram a screwdriver in to the key hole and twist hard and remove the cap.
