Old 10-25-2008, 11:30 PM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
If I remember the instructions correctly you push the adjustment rod all the way into the slave cylinder and them back the adjuster out until you have 1/4 inch of free play on the throw out bearing arm.
Note: It take a fair amount of force to get the adjustment rod to bottom out in the slave cylinder.
DonC
