Old 10-27-2008, 05:58 PM
jams's Avatar
jams jams is offline
Cobra Make, Engine: B & B
Also,
I don't know if it makes a big difference but after drilling the hole to the final size, I like to use a countersink bit to just ease the top of the hole a bit. This way you have a small bevel around the drill hole. I find you don't get as much splintering and it allows for the screw to go right in. I believe it also stops the paint from chipping beyond the drilled hole.
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
