Old 10-28-2008, 02:42 AM
undy's Avatar
undy undy is offline
Originally Posted by Excaliber View Post
Reliability, hmmm, a relative term. Center (top) oiler rev limit is around 6000 due to it's inherent weakness of splitting the block at the main journal area. You can spin it higher, but it becomes risky. Side oiler is good for 9000 rpm plus because it is an inherently stronger block, that's why they use it for the SOHC version.
427's and the FE's series engines in general get a bad rap as far as reliabily issues go. They ARE a 100,000 mile motor and ARE extremely reliable when built and used within reasonable parameters. The original side oilers were putting out about 475 horse from the factory and were quite reliable. Today we see many builds exceeding 500 horse, the risk factor goes up accordingly. Stroke it, put in a wild cam, build it to 600 horse and rev the heck out of it and you will eventually break it! Of course thats true for all the modern versions of a side oiler block as well.
Side Oilers powered the GT-40's to a win at Le Man's, 24 hours of pedal to the metal. The FE series engines are certainly reliable and strong enough for even a hard core racer.
Actually the inherent weakness of the center/top oiler had nothing to do with block splitting as both side/top oilers were cross bolted which took care of that problem. The non-cross bolted Fees had the high-rpm block failure problems, hence the desirability of the extra block webbing in the 428 Cobra Jet blocks and the later "ribbed" service blocks. I don't believe (not sure though) that the 66 Cobra's 428 PI motors received that extra webbing either. The chink in the top oiler's armor was the lack of priority main oiling. The center/top oilers received oil to the cam first. What was left made it to the crank, maybe. Minor oil starvation conditions caused catastrophic failures in the top oilers. Oil pressure (volume too) to the crank under all conditions was less than with the top oilers too. That's the reason where most will say, other than all out competition (meant to say severe track duty) the top oiler should survive just fine. Most performance engines today, to include my 6 bolt main LS7, receive priority main oiling. lessons learned....
Too many toys?? never!
