Old 10-28-2008, 09:30 AM
Don Don is offline
The narrative in the book mentioned below, from the author's ,George Reid ,viewpoint includes detail comments and pictures on all the BB regarding reliability, casting etc, Too lengthy to type , some very brief excerpts regarding 427:
" Undoubtedly the most desirable Ford high performance block going is the 427 because it shares nothing in common with the rest of the " FE " line up. It's high-nickel content gives it extraordinary strength "
" The earliest 427 blocks had the 390 High Performance oiling system. Ford soon learned that at high revs, the 427's # 2,3,4, and 5 main bearings could sometimes become oil starved, resulting quickly in bearing failure-or worse."
".......Ford cast an entirely new FE casting called the Side Oiler block early in 1965 where the mains receive a wealth of oil pressure thanks to oil galleries which fed the mains from the sides of the block "
Only mentioning what the author states, but the book appears to be a resource.
Previous post:
The CarTech publication " High Performance Ford Engine Parts Interchange " lists 20 Ford numbers from 1963 to 1968 as 427 High Performance including Side Oiler, Industrial and Marine, Chapter 11 page 94, available as a download @ $4.00.
http://www.cartechbooks.com/vstore/s..._ID=2933&DID=6
