Old 10-29-2008, 04:46 AM
blykins blykins is offline
I used the same torque spec. Just put a little moly grease on the threads and torque them down.
I've never seen different setup specs between aluminum and cast rearends. You're basically setting pinion depth, backlash, and bearing preload, which should be the same. The gears don't know what the housing is made of.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
