Old 10-29-2008, 04:34 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
With a cold engine; carefuly remove the bulb end on the intake manifold and put it into a cup of boiling water. Check the gauge...water boils at 100 degrees C. You should be close to that temperature on the gauge. DON"T LOOSE THE BRASS WASHER......
SPFWiringDiagrams@Comcast.net
