Old 11-02-2008, 01:57 PM
J. T. Toad's Avatar
J. T. Toad J. T. Toad is offline
Club Cobra Member
Cobra Make, Engine: Classic Roadsters, 351W -> 392
Originally Posted by Smokingcobra2 View Post
just priced out a Rinia unit for a 2100 sq ft house. runs around 4000.00
joeg
The size of unit should be based on projected use in GPM at peak usage and water inlet low temperature.... IOW, how much use at one time @ what temp.
$798 for 27KW - bear in mind, this is a huge supply of hot water... that's right 27KW! which means whilst it is on max draw, your meter will be spinning at cobra speeds!
It is funny, I never thought about the 'trickle' issue. I never use hot water in a 'trickle' mode, but, alas he is right. The difference between trickle and low flow is hardly noticeable.
"Smooth seas do not skillful sailors make"
"If you can read this, thank a teacher....and since it's in English, thank a soldier."
