Thread: Body Vibration
Old 11-02-2008, 08:19 PM
MaSnaka's Avatar
MaSnaka MaSnaka is offline
DV,
I believe you talked about something similar recently, referring to fitting the body down on top of the firewall. Trimming the top of the firewall and placing a rubber gasket along that edge. Is this the same thing? I know my body is not glued down (or have a rubber gasket for that matter) at the top of the firewall and it seems this would really tight up the body if it was. If I'm on the right track here do you glue it by accessing it from under the dash? And are you suggesting using Permatex RTV silicone? Thanks!
John
