Old 11-02-2008, 08:42 PM
Tim Brewer Tim Brewer is offline
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
As long as you have pressure at the regulator, you should be fine there, but if you don't, the power for the pump should go through a relay, always. What are your primary and secondary jets? Also, with the engine off and the air cleaner removed, I would manually operate the carb watching to see that the secondary side of the carb squirts as hard as the primary side.
" It ain't no big deal"
