Old 11-03-2008, 07:03 AM
jhv48 jhv48 is offline
Originally Posted by FWB View Post
is anything done to the motor, meaning if its just a mild built windsor a 750 dp
will be too much carb. whats the timing set at? if you can get away with a couple of degrees advance more bump it and see if that affects the flat spot
if it does that might indicate too much carb if the flat spot move up in rpms
when it occurs.
I tend to agree with this one. If the carb is pushing too much air into the engine, it will crap out. One thing you can try is putting a very restrictive air cleaner (read that small) on the carb and then drive it. If the condition gets better, then you have found your problem.
That carb could just be pushing too much air for a mild 351W.
