Old 11-03-2008, 08:17 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
As you know pipe threads are a course and tapered thread with an increasing interference fit. If a softer material plug (like brass) is being inserted into a cast iron water pump that also helps it seal. Teflon tape installed correctly does seal if no issue with either the male or female side has burrs or defects. I like the Teflon paste because it is easier to make a clean and neat install for me anyway.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
