Old 11-03-2008, 12:40 PM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Originally Posted by vettestr View Post
As you know pipe threads are a course and tapered thread with an increasing interference fit. If a softer material plug (like brass) is being inserted into a cast iron water pump that also helps it seal. Teflon tape installed correctly does seal if no issue with either the male or female side has burrs or defects. I like the Teflon paste because it is easier to make a clean and neat install for me anyway.
Ditto. Teflon paste is the way to go.
Replica is not a dirty word.
