Old 11-05-2008, 08:07 AM
patrickt patrickt is offline
Originally Posted by davids2toys View Post
Do you use the Amalie in the rear too?
Amalie makes automatic & manual transmission fluid and it also makes a limited slip additive -- do not confuse the two. If you find that your Jag LSD "clicks" around corners, switch away from Amalie and try two tubes of the GM LSD Additive and it will often go away.
