  #58 (permalink)
Old 11-08-2008, 01:19 PM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Dont know where the piston weight comment came from???
FWIW- Budget long rod 351w-- 351w crank (1.75"/1/2 stroke) + 400c/351m rod (6.58"c/c) + piston from 3.25" stroker 302w (1.165" comp height ) for total of 9.495".
Takes some work ( BE needs narrowed to 351w journal width & SE requires pin bush from 272 Y/Block )- + be real careful with valve to Piston clearance due to increased dwell @TDC. Rod ratio is then 1.88/1
Jac Mac
