Old 11-09-2008, 03:29 PM
tkb289 tkb289 is offline
Doug ... sounds like between the McLeod instructions, pressure bleeder, clear tubing & bracket, you should be able to get the air out of the system and get full range of motion from the clutch.
What I use for a catch bottle, is a clean dry water bottle taped to a brick or block of wood and an long piece of clear vinyl tubing. That way, you can see the air bubbles in the tubing and you won't tip over that catch bottle, it saves a lot of clean up.
- Tim
