Old 11-10-2008, 09:02 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
We use ATI super dampners on our builds---for the ford FE the bolt pattern on the dampner is for a bbc and you'll need to offset drill the pulley holes .050 to use original pulleies---if you want to use later or aftermarket just use with a chev bolt pattern
The dampner that I would stay away from is the fluiddamper---every time I see a broken crank it has a fluid dampner on it---
Have you got back to the 767 yet???
