Thread: 91 rmc radiator
Old 11-12-2008, 06:20 AM
LoBelly's Avatar
LoBelly LoBelly is offline
Its Radiator Origami Time - Yay!
(takes two to play)
After removing all vital fluids from the cooling system pop the hood and prop up the front end of the car
The RMC supplied radiator is wider than the mouth of the Cobra and there is not enough room to drop it down between the frame rails.
Get your friend (for now) to unbolt the radiator and slide the forward section up into the top of the nose
Lift the back of the radiator up over the front cross member and lift the radiator out through the hood.
Use a #5 Block splitter to render the radiator inoperable
Measure for a new Upright radiator and place order.
In 3-5 days - after you make up a couple of simple brackets - your cooling problems will have ceased
you have a nice upright radiator like this:
and you wont get a repeat of this...
seriously cooked
mmmmmm
LoBelly
