Old 11-12-2008, 07:28 AM
Wayne Maybury's Avatar
Wayne Maybury Wayne Maybury is offline
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
I set mine up similar to Tim. I connected a 2 ft piece of braided SS hose to the throw out bearing and put the bleeder on the other end of the hose. The bleeder is now just beside my remote fluid resevoirs. It is very easy to bleed as you are actually standing beside the car. Once I was finished with the bleeding, I attached it to one of the reservoirs with a plastic tie wrap which you cannot even see unless you are really looking for it.
One more tip, make sure that there is absolutely no air in the hose between the remote reservoir and the master cylinder as it will only be a matter of time before that air gets sucked into the master which will then have to be bled again.
Wayne
Don't get caught dead, sitting on your seat belt.
