Originally Posted by strictlypersonl
Yes, that would work. You can remove the female spade connectors from the plug with a jeweler's screwdriver, so less wire surgery is required.
Cool. Kramer, remove the WHITE wire and GREEN wire from the voltage regulator plug and tape them off. Jumper the connector where the WHITE wire came out of to any 12v source (for instance, the YELLOW wire next to it or one of the hot fuses on the firewall). Then see if the system charges properly. If it does, you've found your problem.
