  #34 (permalink)
Old 11-12-2008, 01:31 PM
JAM1775 JAM1775 is offline
Cobra Make, Engine: SPF 974
I had my 351W rebuilt after a bad problem from a BG carb. The shop swapped in a polished balanced crank from their shelf which saved time. Two bearings failed within 700 miles. Rebuilt again...by another shop . On a chassis dyno after break in the motor started knocking ...same two bearings burned. Only this time there was a warranty. The crank from the first shop was "rockwell tested" for strength . It was discovered the journals servicing the same two main bearings that kept wearing were soft. The shop rebuilt my motor....again.....and all I paid was splitting the cost of another shop supplied crank. The motor has been running excellent for 21K/ 6 years now.
