Old 11-12-2008, 09:45 PM
cobras cobras is offline
thanks for the reply
"so I am guessing you want
TORQUE... which would be the Edelbrock Performer RPM dual plane manifold...not the Victor Jr."
so would this manifold give me a loss in hp #s from what i have now, what are the diffrences in a dual plane or a single plane
i would have to say yes to the torque, i dont plan on making any new speed records, i just want it to pull hard off the line and have a good strong pull up through the gears, but also dont want to loose too much HP in doing so
here are the specs from the ford web site
392 cubic inch
475 hp @ 5600 rpm (with headers, and a 750 CFM Holley carburetor not included)
495 lb.-ft. @ 4400 rpm
10:1 compression ratio (nominal)
Forged pistons
Forged steel cap screw connecting rods
Hydraulic roller camshaft, .580" lift intake and .602" lift exhaust, duration at .050" is 232 degrees intake and 240 degrees exhaust
Double roller timing chain set M-6268-A302
Forged steel crankshaft
High-performance T-sump oil pan
MSD billet distributor
Ford Racing aluminum "Z" cylinder heads M-6049-Z304DA with 2.02" intake valves and 1.60" exhaust valves
Roller rocker arms M-6564-F351
Single plane “Victor Jr.” intake manifold M-9424-V351
New heavy-duty 5.8L “Sportsman ” block, oil and water pumps, performance oil pan, steel billet flywheel and high-performance harmonic balancer
