Old 11-14-2008, 09:02 AM
RonNichols's Avatar
RonNichols RonNichols is offline
Cobra Make, Engine: SPF398/460ci/ 144hp of backfiring fury
Originally Posted by RedBarchetta View Post
Ron, it's been discussed but never documented. I think it was you that I traded PMs with. Based on the drawing above, is that approximately how you welded up your transition cone? Or was the section that you used too long and your welds were closer to where the collector joins the straight pipe?
-Dean
Dean,
My muffler pipes were constructed different as I had the Classic Chambered mufflers. But your drawing is very similar in pricipal to what I did. If I had your mufflers, I would do it just the way you have your drawing.
You should build a welding fixture if you plan on doing this often.
R
