Old 11-14-2008, 05:40 PM
Dangerous Doug's Avatar
Dangerous Doug Dangerous Doug is offline
Cobra Make, Engine: ERA 289 FIA #2108
marcalan: Really? It looked like I was going to have to do the same, but Doug told me that I can take the lower lever off the clutch and rotate it to get the position I want. Sure enough, I was able to rotate it and get the recommended ~1" throw at the master cylinder. The lock pin is hard to see, as it is on top of the lower lever.
Right now I have the master cylinder rod on the upper hole on the lower lever. If I switched to the lower hole that would get me to about 1-1/2" travel.
Seems to work. I'll find out tomorrow.
Doug "Got-the-Bug": Give me a call so I can crate "The Guardian" (a.k.a. Donner, my German Shepherd, also known as "The DogFather")
Dangerous Doug
"You're kidding, right?"
