  #46 (permalink)
Old 11-16-2008, 03:12 PM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Originally Posted by tkb289 View Post
Sorry to hear about the noise, a compression check will tell you a lot ... maybe a valve lifter or cam lobe is the problem? Just guessing at this point. Since you have the valve cover off, maybe crank the motor a bit an see if it looks like the valves are opening and closing properly.
- Tim
Originally Posted by PANAVIA View Post
did you go over any decent bumps >? is it a loose windage tray >? is there any additional vibration (engine shake) with the noise >? are all the pushrods straight>?
--Steve
I had a chance to check the compression today and it looks good (190 to 195 for all cylinders). I checked the basics and found no oil in the water or water in the oil. I also drained the oil and it looked fine. I replaced the oil/filter and started it up again this afternoon. The engine started right up, no shaking, smoke, or anything unusal...except for the knocking sound.
Since it's under warranty, I'm not going to turn any bolts. I've got a call into the Roush dealer in Reno and I'll go from there.
Doug
