Thread: Body Vibration
Old 11-16-2008, 08:21 PM
Double Venom's Avatar
Double Venom Double Venom is offline
It ALSO CHANGES PINION ANGLE! Measure the degree of your driveshaft!!!!!!!!! At ANY setting (of the rear end height) plus or minus 3 degrees negative is pretty critical. You do not want it perfectly flat/horizontal/level. Underload the pinion on the rear end will want to raise, you never want it to go or close to a plus/positive degree!
Sounds like you are winning ???
DV
