Old 11-18-2008, 09:16 AM
Dangerous Doug's Avatar
Dangerous Doug Dangerous Doug is offline
Cobra Make, Engine: ERA 289 FIA #2108
Default SW tach problem...solved
Pulled my tach out to check my connections. There are five connections on the back (and bracket) of the SW tach:
POS
NEG
SIG
Light
Ground is a tab on the bracket side
SIG goes to the (-) coil
POS goes to a fused power source
Light, well, that's the light connection
Ground is a shared ground wire from the fuel gauge
NEG ---> This needs to be connected to ground.
I had left NEG floating, having assumed the case and bracket provide adequate ground. They probably do, but NEG cannot be left floating. Tie it to ground.
Tach works fine.
Dangerous Doug
"You're kidding, right?"
