Thread: clutch on CR's
Old 11-23-2008, 10:23 AM
MaSnaka's Avatar
MaSnaka MaSnaka is offline
The instructions that came with the clutch master said NO SILICONE fluids as they will destroy the O-rings. They recomended using DOT-3. Would the silicone fluids be clearly labeled "SILICONE" ? I recently added some fluid to the reservoir labeled DOT-3 with no mention of it containing silicone. I hope I didn't screw up.
Up until recently I had a bit of an oil leak dripping off the bottom of the bell housing. With no more oil leak I can now see what appears to be clutch fluid. 1 little drop about the size of a penny after a drive.
I'll check out the Tilton products and confir with the tranny shop Monday.
Thanks.
John
