Old 11-24-2008, 05:27 PM
Default QA1 with both adjustments
Danr55 Dan the QA1's with both rebound and dampening are top of the line. You will have to measure your shocks from eye hole to eye hole for the correct length. Shop the internet for the best price. I got mine from a dirt track race shop out of Maryland with springs for a better price than either Jegs or Summit without the coil springs. You will need you spring rate also. Alot depends on what you are looking to do with your car. Maken it handle better? If this is the idea than you will increase the spring rate by about 35%. The ride will be stiffer but handling will be alot better. There are like 500+ settings on the QA1 shocks, Koni are 3-5? and for dampening or rebound, not both. Rick L. I have Spax in my ERA, it drives and handles alot better with the new springs and shocks. Rick L.
