Old 11-26-2008, 04:14 AM
Default call me tonight Doug
767Jockey Call me BEFORE you pull that Yoke. You need to mark it. Nut and pinion. You should also get a drag load rate before also Rick L. If you over tork the pinion bearings you will get to much backlash and per wear out the bearings. I will be home after 7:00pm
