Old 11-26-2008, 09:10 AM
767Jockey's Avatar
767Jockey 767Jockey is offline
Originally Posted by RICK LAKE View Post
767Jockey Call me BEFORE you pull that Yoke. You need to mark it. Nut and pinion. You should also get a drag load rate before also Rick L. If you over tork the pinion bearings you will get to much backlash and per wear out the bearings. I will be home after 7:00pm
I'll give you a call Rick - thanks!
