Old 11-29-2008, 03:53 PM
cb6577 cb6577 is offline
I just ran into a pushrod length problem on my 428.I am using comp super roller lifters,mech roller cam, edelbrock heads,ferrea valves and .060 lash caps.Originally I ordered the 9 and 3/8 pushrods from Lunati,they were too long.Lunati does not include the cup when stating the length.so I got a checker from trickflow for 8.3 to 9.3 Inches in length.I determined my motor needed a 8.950 length.Now Smith Bros. pushrods was going to make a custom set for me for 28 $ each.Keep in mind I have 800 lbs of open pressure.So at that price would have been almost 500 bucks a set.So what I done was found a used set of jesel rockers from a nascar cup shop(they are all over ebay) for 100 bucks.They have the adjuster screws that will fit directly in a set of Comp Roller Rockers for FE and allows you to use a ball tip pushrod for the rocker end.Then I found a set of pushrods that were double tapered .125 thickness from another used cup parts vendor and was able to get them for 30$.Not only did it save me some money,but alot of cup motors use a 8.950 length pushrods and every other cam and pushrod company makes them everyday with the ball ends.So if you are ever in a bind there is a good chance jegs or summit has them in stock. The screws I was referring to was from jesel,they use 3/8-24 threads 1.25 inches long and use a 5/16 ball.If you can get ahold of a set of these and change to a double ball ended pushrod it will save you alot of trouble from buying custom pushrods.
