Old 11-29-2008, 07:44 PM
cb6577 cb6577 is offline
The trick flow rod with the cup end is 5/16 cup but probably would get you close enough.On a FE shaft mount rocker system the pushrod length does not have any critical effect on rocker arm geometry like a stud mount rocker.So as long as you are close on the measurement you should be fine.
