Old 11-30-2008, 02:34 AM
CobraV8 CobraV8 is offline
Default 9 inch rear end questions
I'm building a custom 9". As far as I understand, the pinion angle should be at +3degrees. Does it also make sense to center the differential under the car, or should it be offset with one axle tube longer than the other? Axles have to be custom made anyway, so that wouldn't be a problem.
Thanks, Simon
btw does someone have a set of the weld on brackets for the axle housing left over and wants to sell it?
