Old 12-02-2008, 04:15 AM
byroncobra's Avatar
byroncobra byroncobra is offline
Thanks fellas
Panavia...if you are referring to model years, mine's a '92 from a HO Mustang. I considered mount may be upside down or reversed but that's not the case (unfortunately)
Merv...Ill get onto Warrick tomorrow. It'd be a pitty to toss the T56 I think although Warrick has mentioned that 6th gear is hardly needed. I may just have to hack and grind the chassis members to make it fit. Its a bugger that I went to the trouble of lining it all!! Interesing that you need to pack out your mounts, I'd hoped that Warricks' chassis would line up.........sounds like she's almost back from the paintshop, did you not fit up the engine before sending it off there?
Greg
