Thread: Body Vibration
Old 12-04-2008, 10:37 PM
tcrist tcrist is offline
Ok, trying to get to the root of it all. This is what I understand so far.
1) get everything on the ground with the body on with the tires that you are going to run.
2) set your ride height.
3) make sure that your motor is level or a little tilted nose down to the horizon. How much 1-2 deg?
4) set your pinion angle so the nose of the rearend (where the driveline bolts up to) is about 3 deg down.
Please correct me where I am wrong.
I just received my double adjustable upper trailing arms and trying to get it correct in my mind before I tear into it.
Terry
