Old 12-08-2008, 02:01 PM
Larry N Johnson's Avatar
Larry N Johnson Larry N Johnson is offline
Cobra Make, Engine: FFR 3850, 95 Cobra 5.0 EFI, IRS, Pin Drive 15" real Magnesium Halibrands & Vintage Wheels, Billboards & Mickey Thompson S/T tires, Blue/Wht Stripes, Hoops, CSX Dash, Konis, VPMs, Torsen
Default 325/50x15
Originally Posted by DocDirk View Post
So as I understand it...it's too simplistic to say that any given set of tires must have a front to rear ratio to perform well... the jist of what I'd been told was that going to 335's on the rear would cause the car to "push" in turns, wanting to go straighter than a smaller rear tire would. I see your point on diameters, Larry, thanks. I'm just wondering if I could increase the rears to 335 for straight line traction and (given the identical setup) not cause a net loss of decent street cornering manners.... and yes, I understand no such question has a simple answer!
Thanks and ride safely
Dirk
If your roadster will fit 335's and it will help straight line traction and accelleration, then go for it. Here is an example of a 325/50x15 tire drag racing in an SPF:
Greg Schroeder from Scottsdale, AZ says
easy start video
10.91 @ 128.75 pass
- What gear ratio is yours?
Ford 8.8 3.73 with Detroit Truetrac, Tremec TKO 600 and the tires for drag racing are Mickey Thompson ET Street Drag radials, 325/50 15, actual height 27 inches tall.
- What engine?
Roush 427R-095 with single plane intake manifold
Switched carb to Pro-Systems 1000 cfm double pumper
switched to 2 inch primary headers
switched to Buckshot Racefab side pipes
- Total weight?
race weight should be 2550lbs with me in the car and gas.
My SPF number is 2040. Mine was one of the last ones with the Ford 8.8 3.73. I'm not sure exactly which number car they switched, but the new SPF cars come with a Dana rear end which I believe is the same type in a new Pontiac GTO.
