Old 10-24-2001, 08:27 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Wink
Jim,
First off, what type of rack do you have now?
Second it can be done. "MARCH" pulleys has finally made a set of pulleys for either a left or right hand turn water pump. Simply buy a set of pulleys and brackets from MARCH. Then find a new or used pump, two power steering hoses, and a rebuilt power steering rack. NAPA has them at a fairly decent price.
Then after a few hours of labor installing all the parts it will simply need to be re-aligned.
Cost: Conserveatively $850.00
However if you are using a power rack that has been "blocked off" then may I suggest a Flaming River rack. Around $200.00 and you will think you have power steering. If you have a FR rack then see above!
DV
