Old 12-09-2008, 06:57 PM
wtm442's Avatar
wtm442 wtm442 is offline
Beam Me Up Scottie
Grab the spark plug lead with either hand while standing in a puddle. Your eyes will blink 8 times a second (the brain only can take in info at that rate), which is ideal for any V-8 engine. You wasted good money on a timing light.
Try it with an old style magneto and we will call you Rudolph.
Inductive pick-up around plug wire #1. Pos lead of light to battery cable on firewall (starter solenoid). Neg lead grounded somewhere that is a good ground. If no flashing, try another ground.
On some inductive timing lights, they do not always work with spark plugs gapped up in the 0.045 range or higher. You may need to temporarily close the spark plug gap to 0.030 to get the light to work properly. Do not ask me how I know that.
Warren
