Old 12-11-2008, 07:26 PM
Blittleton's Avatar
Blittleton Blittleton is offline
CC Member / Sponsor
Don,
Are you pulling the motor and trans by yourself? I have installed and removed motors by myself and I have pulled trans and left the trans on. It is what you feel most comfortable with. Please pull the hood off and have as much room as you need. T-5 trans are lighter than most I've pulled, so remove it first if you need to. Hint, if pulling the motor and trans together, use a floor jack under your trans while pulling both motor and trans. this will allow you to move the unit together with more ease, instead of dragging it on the garage floor.
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
