Old 12-13-2008, 04:16 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
Default tune your exhaust
anybody like a post of the one shown below send the information and i will try to post the results. supposed to be pretty correct within inches proven on dyno. in order of importance: primary size, collector length & size, primary length. from what i understand equal length headers haven't shown the benefit worth the investment. might just do this for a few engines and everybody could use the info.
bore
stroke
rod length
peak hp rpm
comp ratio
int/ex valve dia.
valve stem dia.
int/ex valve lift
int/ex valve lift
int/ex dur. at .050
int degreed centerline
lobe center angle
centerline length of ex port from valve face to manifold mounting surf.
some of the above can be estimated and similiar engines will not skew the results much.
the below is for a 3.80 stroke 4.125 bore making peakhp at 6600rpm
--- Single Primary Pipe Specs --- for 406.268 CID from 4600 to 7100 RPM
Diameter= 1.752 to 1.877 Length= 27.4 to 30.3 inches long
--- 2-Step Primary Pipe Specs ---
1st Dia. inches= 1.752 Length= 13.7 to 15.1
2nd Dia. inches= 1.877 Length= 13.7 to 15.1
--- 3-Step Primary Pipe Specs ---
2nd Dia. inches= 1.877 Length= 6.9 to 7.6
3rd Dia. inches= 2.002 Length= 6.9 to 7.6
--- Header Collector Specs (Conventional Straight Tube) ---
Diameter= 3.215 to 3.465 Tuned Lengths= 16.2 best and also 8.1 or 32.5
--- Header Collector Specs (Megaphone or Diffuser Cone Shape) ---
Diameter= 2.715 taper to 3.715 Megaphone/Diffuser Length= 16.2 inches
Best HP/TQ Tuned Collector Lengths= 16.2 , 32.5 , 65.0 , 129.9 inches long
Worst HP/TQ Loss Collector Lengths= 24.4 , 48.7 , 97.4 , 194.9 inches long
Note-> all Pipe Diameters are OD and based-off .0625 inch Pipe thickness
---- Primary Pipe's Harmonics ----
1st Harmonic = 121.8 inches long ... typically never used
2nd Harmonic = 46.0 inches long ... longest recommended
3rd Harmonic = 27.4 inches long ... highly recommended , best Torque Curve
4th Harmonic = 19.1 inches long ... shortest recommended
5th Harmonic = 14.3 inches long ... typically never used
6th Harmonic = 11.2 inches long ... typically never used
7th Harmonic = 9.0 inches long ... typically never used
8th Harmonic = 7.4 inches long ... typically never used
---- Collector's Harmonics (includes Intermediate, Muffler , TailPipe) ----
1st Harmonic = 129.9 inches long ... longest with Mufflers and TailPipes
2nd Harmonic = 65.0 inches long ... longest recommended with Mufflers
3rd Harmonic = 32.5 inches long ... more bottom-end Torque
4th Harmonic = 16.2 inches long ... highly recommended , best Torque Curve
5th Harmonic = 8.1 inches long ... reduced Torque , more top-end HP sometimes
6th Harmonic = 4.1 inches long ... reduced Torque , not recommended
