Old 12-13-2008, 08:58 PM
computerworks's Avatar
computerworks computerworks is offline
Originally Posted by 767Jockey View Post
Is there a better switch for me to use that is more original looking?
Nope...that is the one used on the real guys.
Easy to test with some continuity tester, like a simple ohmmeter or low-voltage test lamp.
The three wire set is the directional...one wire is the "wiper" that will connect to one of the other leads in one position and the other in the converse position.
Test for continuity in each position; i.e., the center lead will be shorted to one wire in either position.
The button is just a momentary-contact switch that shorts the 2-wire pair together when pressed.
