Old 12-16-2008, 08:47 AM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Originally Posted by xracerbob View Post
Cobred-
It was mostly small detail stuff for instance- I wanted a 1/2" fuel line from the fuel tank with a return line connection in case I wanted to go with fuel injection in the future. They had already done this for other people. Also, I had them put in stainless steel brake lines.
There are a couple other things that if you don't specify, you might not get what you wanted. There are 2 radiators for the 427 car- one for the expansion tank option and one without. Its the same radiator, the inlet tube is different.
Hey Rick- my car is 2365 with 5 gals of fuel (no seats or carpet in yet). 15" wheels, ERA rear, Pond aluminum FE, QT bellhousing, aluminum flywheel, etc. You can get the weight down there.
The easiest place for him to start would be to go on a diet
Replica is not a dirty word.
