Old 12-19-2008, 04:32 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
One other thing regarding the AMP bouncing issue, we'll do the cheap stuff first.
There are two main grounds on these cars. One back by the battery and one on the chassis, passenger side, below the starter. Hi-Tech put a fantastic layer of black paint on these chassis's - And they paint the grounding lug just as nice...I would suggest that you get under there, remove the grounding cable (up front) wire brush that grounding lug to a metal finish, reinstall the cable using a star locking washer, and then a little di-electric grease to prevent corrosion. You can usually get a little packet of the grease at the parts stores. This takes a little time and effort, but has cured many ill's with the cars...try it....
SPFWiringDiagrams@Comcast.net
